Ahhhh! Which ones are which?
Davidwyby
236
CA
Is there someplace I can look and see what all the different numbers/models of the trucks designate or refer to? I just started surfing the 5ton and up forum and I see tons of different designations. :oops:
Davidwyby
236
CA
Another. Why doesn't your sig go onto all your posts when you add/change it? Looks like it only goes on the posts you make after you change it.
CARNAC
The Envelope Please.
686
Corpus Christi, TX
You can also check the TM's. Usually a TM covers more than one type of vehicle. For example the deuce TM covers the M35A2 w/o winch, M35A2 w/ winch, M50A3 water truck, M109A3, M185A3, M49A2C and maybe one or two others. 800 series 5 ton manual is the same way.
