Air Box Modifications
galaxie428
80
Rushville, IN
Hello all. I have an M998 that I'm doing a 6.2 to 6.5l TD swap on and was looking at all the air box to see what could be done to help with air flow to the turbo. The filter looks like about 1/2 of it is covered with that baffle. Has anyone trimmed that baffle and or the stack to help with air flow? Any negative effects on what modifications you've done?
I do some light offroading with it so there is some dust and dirt where I go. Obviously, I don't want to do anything that will damage the engine but I do want to let it breath more.
Mogman
8,984
Papalote, TX
That air box will flow many times what that turbo can pull, no need for modification.
EDIT, I am running a stock intake with a Duramax, it of course is monitored by the ECM and it has no issues with the stock intake, the numbers all look good (at up to 475HP) and the Duramax of course flows much more that the 6.5T.
the filter itself is grossly oversized to compensate for harsh battleground conditions.
I am convinced they only put the different hat on the Alpha just so it would be instantly identifiable, seeing it only has a 300HP tune in it.
galaxie428
80
Rushville, IN
You are probably correct, just seems like a lot of unnecessary baffles blocking airflow path to the turbo.
Mogman
8,984
Papalote, TX
The 6.5L was the end of a miserably failed attempt by the gasoline engineers at GM to design a diesel engine.
I am not sure who at GM decided to go to folks at Isuzu that REALLY knew diesels to design the 6.6L but that guy deserves a medal, GM went from LESS than 4% of the light duty truck market to well over 30% now
Vapor Trail
263
Kentucky
Because my intake has to be a large K&N. I don't want to look at it all the time (most people leave them out exposed) so I was going to route it into the existing airbox and leave the lid off so it can get more air. That little round cap looks restrictive.
87cr250r
1,973
Rodeo, Ca
You do not want to use K&N filters in dusty off-road environments. They really aren't good for on-road either.
If you want the best of the best, replace the entire filter housing with a Donaldson PowerCore housing.
Vapor Trail
263
Kentucky
The guy that did the computer tuning said this works best so I’ll probably stick with that but I’ll look into the housing. I know Donaldson makes good stuff
Mogman
8,984
Papalote, TX
That is a Donaldson type housing that is stock on the HMMWV, I would certainly not expose my filter to the wheel well where more dirt, dust and rocks can get into the filter.
If you want to stick with the K&N (which I also have a low opinion of because of the maintenance required to keep it effective) just leave it under the hood, sucking hot air is probably better than sucking up dirty air.
Mogman
8,984
Papalote, TX
In fact Donaldson makes that filter #P521242
EDIT, looks like it has been discontinued......
