Air Compressor Pulley wrench dimensions / drawing?
SandBar
Full Time Patriot
755
231
GA/FL
I find myself needing to replace the belt as it failed due to age. I read a post that mentioned the dimensions of the wrenches were posted somewhere but I never found the source post. Does a cad file or drawing exist? Thank you!
runk
65
Houston, TX
You may need to play with the scale if you print it out.
There was a member who made them, but stopped years ago.
SandBar
Full Time Patriot
755
231
GA/FL
DXF would be great of you can PM then to me, I can use it to validate the models I put together here:
Thank you!
gringeltaube
Staff Member
2,260
Montevideo/Uruguay
FWIW, regarding actual dimensions mentioned in that linked post: neither 4" or 4.25" is correct (!)
4.375" will barely fit, so better make it 1/16th larger.
And the net width of the 4 "legs" should be 2.0", not less.
Too loose fit is not an issue here; too tight is.....
Pictured below is what I have...
Not "original" and very loose fit, but it does the job.
