dieselsmokem35a2
- 0
- 0
- Sagamore Hills, Ohio
I was out driving my Deuce the other day and noticed it making a squealing sound once in a while, but only for a second. Got home and popped the hood with the motor running and saw that the belt seemed to be on the loose side. Had a spare so I went to replace it. Long story short I started to pull the pulley apart the next day to replace the belt and noticed that I could not turn the pulley to the aircompressor. Even with a big wrench I could not budge it! I have a spare on hand that I bought a long time ago. I think it is a rebuilt one. It is the single piston kind versus the dual piston compressor that I pulled off. Is the single piston one an older version? Any difference other than the pistons like output or anything? The air breather from the broken one fits on there fine and the main line going to the tanks looks like it will fit but the small copper line going to the presure regulator seems like it has some kind of small block the would bolt on to the compressor and then the fitting for the air line would come out of that. Unfortunitely I dont have this little block. There is a plastic plug stuck in there to protect the holes from the pain process but thats it. Anyone have an old single piston aircompressor that they would be willing to part out? Any thoughts or help would be greatly appreciated! Thanks guys.
