Air conditioner
cjd
Rep of Texas
I finally got the 2008 1123 home. It came with the air conditioner condenser assembly loose in the back, and some kind of roof mounted evap and blower assembly just laying between the seats. I have to assume all this was once mounted to a hard top, but I cannot visualize how. Does anyone have a picture or link showing how this system was installed? I am also interested in any ways it has been adapted by you guys after being demilitarized.
Coug
4,079
Olympia/WA
evaporator unit bolted to the rear wall on the inside, so those long tubes blew into the driver's area.
Condenser bolted on the outside of the back wall, or possibly on the roof.
cjd
Rep of Texas
Thanks, Coug. So, do most owners install the units on a hard top, or do they scrap it in favor of a dash unit?
Mogman, I have been googling it for 6 months. All the results come up for the dash AC unit. I have had no luck with any information the rear mounted units. if you know of a link or 2 I'd appreciate them.
Mogman
8,277
Papalote, TX
I just googled "HMMWV AC" and went to "images" and there are tons of pictures like these
Coug
4,079
Olympia/WA
I have a soft top. I added a solid piece of metal to mount the evaporator in the cab, then purchased a fender mount condenser instead of the bulky external unit because I've changed my configuration a few times and actually use my rig as a truck, not a showpiece.
my thread on that
cjd
Rep of Texas
Very interesting thread, Coug. All I can say is Daaannnnggg...it's a lot more complicated than I was expecting! So, from what I gather, the most common configuration is to mount the condenser with fan assembly inside one of the rear fenders, which requires special brackets and cutouts for airflow. Then the evaporator is however you can mount it, although it usually blocks your rear window.
I will have to think about this for a while.
Mog...those are all different than my system. It does tell me there are a ton of different installations, almost like AC on these vehicles was a custom deal.
Mogman
8,277
Papalote, TX
The fender condenser 100% different, you cannot mount your condenser in the fender with "special brackets"
Coug
4,079
Olympia/WA
Just to be completely clear:
It is a different condenser for the fender mount configuration, and they are different for each side as well. The one with the Red Dot unit is too big.
Depending on how you have your truck set up, there isn't so much a right and wrong as there is a "this is how it's been done before" and how it hasn't been done before. As long as there is fresh air able to move past it, and it's protected from damage, then you should be good.
As for the evaporator, I've heard of people lying them down on their back, or putting them flat along the roof, instead of vertical on the back wall. Only real issue with those methods is the water that condenses doesn't have the drains anymore, so you can have moisture issues.
cjd
Rep of Texas
Thank you both for the info. AC was a priority when I was bidding, since I am in Texas, but I am starting to understand that the military AC is going to be more trouble than starting from scratch. I've got mills, lathes, and welders to make any brackets...but deciding how to orient everything will be the trick. I will have to think about it for a while until an idea becomes clear.
Also, there is a lot of reference to "Red Dot". Is that the company that designed the military AC version?
Action
1,551
East Tennessee
You got a truck with aftermarket a/c. The OEM stuff takes up very little space, none in the bed.
Coug
4,079
Olympia/WA
Yes, Red Dot is a Seattle based company that manufactures add on aircon units for the commercial/industrial sector.
cjd
Rep of Texas
Figures...good engine or good AC, LOL.
Thank you all for the info. I'll study and think for for a while on the best way to install this mess...I'll post the result when I'm done.
Retiredwarhorses
3,874
Brentwood, Calif
we are probably the first company to install fender condensers and interface the red dot evaporator on these AC equipped trucks. You don’t have any other options unless you just just go with some other aftermarket system, and AFAIC, that would be a mistake for 2 reasons, money and nothing else has the BTU rating this Red Dot unit has.
Caactus
180
33
NW Phoenix, Arizona
How would you compare the fender mounted units with full red dot system? My 1165 is.. adequate… but barely able to keep out the Phoenix summer heat.
Crapgame
316
Navarre, FL
I thought about trying to figure out a way to mount that style evaporator on the ceiling between the front seats.
cjd
Rep of Texas
I'd like to keep the red dot it came with if I can. I have a soft top on order. I may fabricate a bracket that puts the fans up high at the roof level, and another (or same bracket with bolts through the top) to mount the evap. That would still leave room under the AC to haul plywood and such. Once I get the top on I will start coming up with ideas. I think I will save the fender condenser as a last resort, if I can't figure anything out for the red dot.
Retiredwarhorses
3,874
Brentwood, Calif
The red Dot condenser is massive and is heavy as hell, as is the evaporator…they can’t be installed Willy nilly safely for the occupants safety in case of collision. I do one of these AC systems about once a week, I’ve installed them every which way, but safety is paramount for the occupants, especially when 90% of my customers state they will have children in car seats in the truck. If you don’t physically have the truck yet, you will see what I’m talking about once it arrives.
