Air dryer service
Jeffval
42
Ramsay Montana
Hi Rustystud:
Air dryer is fixed with rebuild kit. Working great. Lots of water has been reduced to a very fine mist. The truck is fully operational now. Just one mire question about the crank case breather. There's an elbow, facing the front of the truck, which is a air line fitting. The elbow has no hose attached to it. I've looked all over the truck where a hose connected to that elbow would go? Thanks so much. Jeffval
The elbow is attached to the crank case breather.
Jeffval
42
Ramsay Montana
Some trucks that had the water fording kit installed used the crankcase breather as a
Are talking about the air pack vent tube ?
Can you take a picture of what your talking about ?
Thanks.
For some reason your sentence was cut in half so I can't read what you wrote. Can you resend it. And I tried uploading a photo but the site says the file is too large for the server to upload.
rustystud
3,383
Woodinville, Washington
I was saying that some things like the water fording kit used the vent tube as a point of exit for their vents. Also, the brake booster sometimes used this too. That is why a picture is best to figure out things.
