Air escaping from under the hood
sermis
17
Temple, TX
I have not driven the big ugly in a couple weeks. 67 M35A2. I went about 2 miles from the house and was making a stop to buy a winch from a rollback wrecker. As I rolled to a stop there was a pop from under the hood and I could hear air escaping and pressure dropping. Turned off the truck and when I re started the pressure built to around 60-70 with air escaping.
When I got home I checked and air was coming from the regulator valve or what ever it is that is on the firewall close to the passenger side. Is there a repair kit for it or does it need to be replaced. I also put my finger over the air intake on the air compressor. It would pull my finger tight but not really suck it in. Is this normal?
1,827
RE: Air escaping from under the rood
They are dirt cheap, replace it! OD Iron has em.
doghead
4 Star General /Moderator
1,193
NY
You can get them at your local NAPA or whatever you have near you. Should cost les than $20.
3,164
Air governer. They are way simple. Alot of times, if things sit, you can give it a squirt or two at both lines going into the governer with marvel mystery or an equivilant air up and give it a few love taps and it will free up
