Air filter questions
mattgunguy
Springfield, Mo
I'm wanting to know what type of air filter to run in a environment with heavy airborne particulate matter. Something on the order of a heavy sandstorm. Or what steps could be taken to protect my motor in such an environment should the need arise. My Google fu hasn't been of help on this.
Thank you
WILDBOY6X6
Newark ca
HI what type of trk is it? I would get a washable type (like K&N) and or a cover for it like used on the CUCV's.
pm me if you want I have a good source for filters washable ones.
mattgunguy
Springfield, Mo
Wildboy6x6, it's a 1970 m35a2 Ltd-465-1c. With no real engine mods to speak of.
Gimpy, that Centri precleaner looks really cool. Except the price tag. Do you have any Persian experience with one?
gimpyrobb
dumpsterlandingfromorbit!
27,786
752
Cincy Ohio
I don't, but I have seen many dozers and trackhoes with them installed.
LowTech
151
Arizona
It has this number - 19207 10912373
I don't know if that's an NSN, or part #, or something else all together.
mattgunguy
Springfield, Mo
Well, I do believe I'll pick up a precleaner before long, & find a stock filter to go with it. Thanks for the idea gimpy. Wouldn't have thought about it myself.
tim292stro
40
S.F. Bay Area/California
I bought a Donaldson TopSpin to use with the XM1027 project (CUCV knock-off). I'm putting it before a Donaldson PowerCore two-stage air filter using a custom snorkel duct. The Donaldson PSD series is rated for "heavy dust" filter is what Oshkosh is using on the new MRAPs and L-ATV prototypes, it has several rows of cyclonic particle separators (think Dyson bag-less vacuum cleaner), right before a ridiculously high capacity and flow air filter (dry-type, not cleanable) with an internal backup filter. There is an outlet for the pre-cleaner which can either dump the separated dust to ground, or be used with an exhaust aspirator to suck it out of the air filter housing and blow it out your exhaust pipe (like heavy construction vehicles do in very dusty work-sites).
They aren't that expensive either, I paid $300 for both parts, filters for the PSD10 I bought are $66 for the primary, $35 for the safety filter. Recommendation is to change the primary filter every second oil change, and the safety filter every third primary filter change - with a "FilterMinder" type device you can stretch the filter interval to when it's needed, not when it's easier to remember to check.
[EDIT:] If you're really worried about dirt/dust, the air filters found on most quarry trucks are also Donaldson two-stage air filters:
Donaldson SSG [/EDIT]
[EDIT 2:] YouTube video on how (and how well) the spinning pre-cleaners work:
[/EDIT 2]
