Air force Deuce brakes
AMX
Walland tn.
I am looking at a duece with the dual braking system. Is this the same system used on the A3 duece? Are the parts available to repair or replace if the need arises? Is there any advantage over the standard system , other than safety?
jwaller
19
Columbia, SC
ya, more pm when the time comes. I would imagine that with double the number of boosters and master cylinders that you would be able to generate more braking force in a panic stop.
AMX
Walland tn.
ya, more pm when the time comes. I would imagine that with double the number of boosters and master cylinders that you would be able to generate more braking force in a panic stop.​
Ignorant me thought it just had a double reservoir master cylinder like a passenger vehicle. auaaua
AMX
Walland tn.
So is one system for the front and the other for the rear? I wouldnt be surprised if some genius split the system side to side!
