Air Governor Gasket
rtadams89
Phoenix, AZ
I am about to replace my air governor on my M35a2 as what is currently on there a) does not look like a military stock governor and b) has its adjustment frozen and isn't allowing enough pressure to build. I ordered a replacement governor from a vendor on here and it came with port plugs and a gasket (image attached). I know where the port plugs need to go, but what is the gasket for? My currently installed governor doesn't have a gasket, the TM -20P doesn't show a gasket, and I can't see a purpose for this gasket. Is this just a buffer between the firewall and governor?
rtadams89
Phoenix, AZ
After some more research, I'm guessing this gasket is included as it is a part of the Bendix kit, but isn't used in the M35A2 application. Is that correct?
TGP (IL)
35
Metro East IL
Yes.
The governor on the M35 is remotely mounted, don't need the gasket.
On some truck(most) mount the governor to the air compressor. Then
You need the gasket.
Tom
