Air horn woes
tbar123
24
enon,oh
When the battery is turned off the horns stop. I have taken all four screws loose on the horn switch box(1 at a time) to see if those were grounding. No change every time the battery is turned on the horns blow!
Cape Coastie
CWO4 ENG/MSS, USCG, RET.
528
124
Sandwich, MA
Sorry tbar, I misunderstood. Thought they were sounding anytime the pressure was above 60 even with the batteries off. You got me on this one. Good luck. But I think you are looking in the right direction with chasing the grounds.
tbar123
24
enon,oh
Your good Cape, I do appreciate any advice, because I'm completely stumped on this. Here is a few pics of the wires I jumped.I suppose pic 2 is the diode. Pic 1 is where 25 and 25A split.IMG_20160217_125130052.jpgIMG_20160217_125134569.jpg
tbar123
24
enon,oh
No it does not, I tried that when I was jumping the wire. When the horns started to blow I disconnected the ground and the horns continued to blow.
The HUlk
Cincy, OH
I'm not sure, 25 was connected to the solenoid,and 25A ground to the firewall was disconnected.
A jumper across the diode will cause the horn to sound. I would remove any jumper and disconnect 25A at it's ground point. Then see if that stops the horn from sounding.
tbar123
24
enon,oh
I'll try that after Mom gets out of bed! I think she'd kill me if I started blaring those horns when she's in bed!
1,185
Air horn woes!
I have no schematics to look at and I'm on my phone but I keep thinking the horn button in the steering column simply grounds to activate the horn isn't the power on whenever the ignition switch is on so where are you disconnecting the ground
tbar123
24
enon,oh
Doghead, I've removed every ground (1 at a time) except 25 the wire to the solenoid and the horn continues to blow.The only wire that will stop the horn is disconnecting 25 from the horn switch located at the bottom of the steering column.
The HUlk
Cincy, OH
Power ia always supplied to the solenoid from wire 26 as you mentioned. GND is supplied to the solenoid through wire 25 when the horn switch is pressed as you mentioned. Wire 25A is tied to GND, has a reversed polarity diode, and connects to wire 25. The reverse polarity diode should not allow GND to reach the solenoid which would cause the horns to sound. However diodes sometimes short internally when they go bad. The reason for removing wire 25A from GND is to be sure a shorted diode is not causing the horns to sound.
1,185
Air horn woes!
So if he tried it with the diode disconnected and it still went off, it sounds like the problem is in the wire going through the steering column. which could be simply tested with an ohm meter.
The HUlk
Cincy, OH
If this is the case then the horn switch is providing GND to the solenoid when not being pressed. Figure out why this is happening or get a switch that doesn't do this.
1,185
I would remove the horn button and disconnect the wire at the bottom of the steering column and test with the continuity test took around to see if that wires shorted it most likely is
The HUlk
Cincy, OH
Correct, however he says wasnt sure whether or not a jumper was in place which would cause the horns to sound. That is what I wanted him to confirm. Now that he has explained removing GND from the horn switch stops the horns, it's obvious there is contact through the switch when there shouldn't be.
tbar123
24
enon,oh
THe second test I plan to run today is take the box off of the steering column horn switch and then see if the horn still blows. If it does then the cover isn't making contact, if it does fix it then it is making contact and I'll have to fix that.
