M2116x6
- 0
- 1
- Langhorne, PA.
I'm having trouble finding the rubber air hose that runs from the cab firewall tubing to the frame tubing on my M211. This for the pressure line that comes off of the junction block on the firewall. When you remove the floor pan, this hose is under the right upper corner.
Local hose / pneumatic shops do not carry these end fittings. Memphis Equipment does not carry the hose.
Does anyone know of a source? Or, does anyone have a complete parts book that would shop the part number? It is 10-1/8" long, 3/4" O.D. hose with male threaded ends that have an inside taper to seal against a ferule on the tube.
Thanks,
Jim
Thanks,
Jim
