Air Hose help needed
M2116x6
Langhorne, PA.
I'm having trouble finding the rubber air hose that runs from the cab firewall tubing to the frame tubing on my M211. This for the pressure line that comes off of the junction block on the firewall. When you remove the floor pan, this hose is under the right upper corner.
Local hose / pneumatic shops do not carry these end fittings. Memphis Equipment does not carry the hose.
Does anyone know of a source? Or, does anyone have a complete parts book that would shop the part number? It is 10-1/8" long, 3/4" O.D. hose with male threaded ends that have an inside taper to seal against a ferule on the tube.
Thanks,
Jim
topo
272
farmington NM
Jim you need two 1/2 unions for nylon tubing the ones that thread on not the new push pull ones and some 1/2 nylon air brake tubing or replace the whole line with the same 1/2 nylon tubing that way it's all one piece . I also have a hose that came off a m211 it looks very good but it's 50 years old . kenny
