- 313
- 598
- 93
- switzerland
Hi togetherI
I have, so I guess, a diesel / air / line poblem.
The history:
My truck ran after a long tour in quite warm outside temperatures and after very heavy rain only with about 80% of the power.
I didn't notice it right away, but it was noticeable.
So I guessed water in the diesel. It had been raining very hard for days and I was refueling in the country.
So I put "Dry Fuel" additive in the tank and went to take a sample at the front left drain cock. With the engine running, as I know it.
To my surprise, however, no diesel came there. But I heard air hissing. And I suspect the came not out but in!
As a result, the engine went out and did not start again. Air in the system.
My question 1:
Why can there be a vacuum there? The diesel filter should be under pressure from the pre-feed pump on the engine yet!
Further history:
Since I now had air in the system was the opportunity good to change the diesel filter.
I noticed that there was already in Barstow times botched. A screw sat only in a helicoil. And that very loose.
Question 2:
That this was still tight I can not imagine.
But then I should have seen that diesel leaks.
Because I assume that the feed pump here generates a certain excess pressure.
Or is it so minimal because it is just reduced again via the return?
Question 3:
Whereupon the third question arises for me.
Can it be that the IP has sucked via the probably no longer correctly sealed diesel filter?
If so, can this lead to the observed loss of power?
For the rest of the story:
Inserting a new helicoil was not possible. Not enough meat there. So I drilled through the thing and closed with screw / nut.
Should now be tight now.
Question 4:
For me, the question now is how to check.
That I have to bleed the whole system now is so far clear. So pressure on the tank and fill the diesel filter before via return line manually.
Open an injection line in front, crank the engine, and wait until I am wet.
But can I check whether the pre-feed pump in OK? Can it be that this has delivered too little and therefore the IP has drawn air via the defective seal of the diesel filter?
These mechanical pumps should actually be indestructible. Especially with well lubricating diesel.
I don't like it when I can't figure out the original problem. But I only know the current symptom, not the cause. Translated with www.DeepL.com/Translator (free version)
The history:
My question 1:
Further history:
Question 2:
Question 3:
Question 4:
