Air intake for compressor
Oldgrunt
Lancaster Ohio
Kipman and I were discussing the feasability of connecting a hose from the compressor to the air filter can. Kipman said there is a place on the air can to install a hose, we were guessing that it may be for the compressor anyway, part of the fording kit. We also were toying with the idea of putting a achohol drip into the line. Any thoughts?
emmado22
163
Mid Hudson Valley NY
The air compressor has a filter already on it, and alcohol evaporators are pretty commonly added accessories from the unit.
m16ty
227
Dickson,TN
If you hook it onto the filter can it will draw air from the housing but not through the filter. Most civilian trucks draw comp. air from the engine air filter but for some reason the multi-fuel has it's own seperate filter.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
Drill the housing right and you can have filtered air. Twice, I guess, since it has an air filter already.
goldneagle
1,460
Slidell, LA
The existing tubing in the back of the air filter housing is not "filtered air" since it is to the outside of the filter cartridge. The air coming from the air intake also connects to the outside of that cartridge.
