dieselfuelonly
- 1
- 0
- Chapel Hill, NC & Greenville, NC
I went searching under my "new" Deuce today for the air leak that I have been hearing. It appears to be from a small pinhole in one of my air tanks under the mounting straps.
Here is a picture - you can see the damp spot by the strap where the moisture has been leaking out. I turned the drain valves on both tanks and only a drop or two came out.
I guess I should replace them - I searched and found a couple sources for replacements. Should I replace both tanks at the same time?
Thanks,
Dennis
![](http://i2.photobucket.com/albums/y23/Diesel_Fuel_Only/airtank.jpg)
![](http://i2.photobucket.com/albums/y23/Diesel_Fuel_Only/airtank2.jpg)
Thanks,
Dennis
