Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
There is one in and one out its the air feed and fill air out from the ctis valve body. The little filter thing is on the fill line. They both connect to copper line on the way thru the firewall. If you look by the governor on the engine side of the firewall the copper ctis feed line usually has a loop before it goes in.
The valve body makes noise but not continuous. See if a standard schrader valve from a tire stem will screw into the bottom of the little filter where the air is leaking. There is also an oring where you screw the basin piece on.
Will
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
