crazyplowboy
- 4
- 0
- Champion, Ohio
I drove my deuce to work and home today with no problems. After supper I started it up and heard a hissing sound. After looking everywhere if found the culpret. There is a switch or distribution block of some sort located just to the right of the steering column. There is a wire going from the bottom of it to the power switch, and a wire on the top that runs to the low air buzzer. An air line runs in to the front of it, and there is a cap lightly pressed onto a fitting on the right side. The air is slowly hissing from the capped off fitting on the right side. Is this supposed to do this as a pressure release or something? I looked all over trying to learn what it is, but could not find any info.
I will try to take some pictures tomorrow
