Air-O-Matic airlines?
micky
SE WA.
So I installed the air assist and had a question as to the routing of the airlines. Someone posted a pic of a nice installation showing the lines with bulkhead fittings thru the frame, my question is it alright to drill holes thru the frame or could this lead to cracking. I know semi road trucks have a requirement of no drilling or welding on the frame due to them being hardened.
Thanks, Mick
Jones
Sacramento, California
Drilling is OK (just look at the frame brackets on the baby HEMTT). Welding is frowned upon because of stress risers at the edges of the weld heat spread.
forklift
Could you tell me what you think of the steering? Was it worth the money? I want to do something like that but I hate to spend all that money to find out they suck. Someone told me they didn't like the air assist. anyone have an opinion on this hydrolic kit from chuckstrucks? It's $950 plus $200 for a line kit.
Dieselsmoke
CA/NV
I'm not too sure on the hydraulic one there. It's got a Char-lyn type steering valve like we use on the monster trucks. I don't see any way that you could possibly mount that steering valve other than by replacing the steering box, which would lose your mechanical backup should anything happen.
micky
SE WA.
Thanks Guys, Drilling it is. I really like the steering. It doesn't assist going down a curvy hill but at the bottom the sharp corner was with one hand and it returned to neutral on it's own. You can still feel the road, no wandering like power steering might feel to some. Sitting still, one hand lock to lock. I think it will be great off road, will let you know when I try it.
Thanks Mick
Adamlee
Alexandria, VA
deuce air-assist steering feedback
On this subject - I also was wondering if some owners/operators running the air-o-matic kits might chime in with their experiences thus far.
Seems to me that with a super singles conversion, an air-o-matic power assist would really make a deuce even more fun to drive....and I agree with the notion that it should really improve any off-roading capability!
I remember back when I had an M880 BEFORE p/s conversion with W100 parts versus after, well, you know how you can get spoiled with power steering driving in a muddy rutted trail.
Adamlee
Alexandria, VA
Air-o-matic power steering
Thanks for the opinion, 1075!
BTW, if you could screen out some M113's for the fire dept, I'd be willing to come visit....
wallew
While the air assit kits are nice, they are nothing compared to REAL power steering. And the conversion is NOT that difficult. Gringeltaube (Gerhard) has done one and posted the process with pix AND the overall results.
Here's that thread -
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=3094&highlight=oil+grade
Deuce Doctor (Randy Barnes) and I are going to do them to our deuces. The major hangup is finding the 5 ton power steering pump that just bolts up to the multifuel. Then all you need is a Ross HF 54 power steering head, which bolts up (with attachment hole enlargement) to the same position as the manual one. If you lose power steering, you can continue steering manually.
jim
Adamlee
Alexandria, VA
air assist vs true hydraulic ps for deuces
Jim, I was under the assumption that conversion to 5-ton ps wasn't possible due to the lack of room for the actual gearbox in the way the deuce motor/frame is set up.
Please, enlighten me as to how I might be able to use a 5-ton hydraulic ps setup instead of an air-o-matic! I might actually save some money!
I thought that anything along these lines meant butchery of frame and/or motor mounts etc....
carguy455
Eddington, ME
alternatives ?
Are these used in any "commercial" applications ? Any other trucks use these ? Looking for additional sources to scrounge from. Or any other stock power steering boxes that could be adapted to the M35's or M37's. The kits are kind of cost prohibitive for us "working" guys. Fabrication or adaptation sound far less exspensive.
davemccoull
Nelson Lancs U.K.
deuce power steering
I work for T.R.W. in uk. and have found out the ross hydropower 54 steering box is indeed made by trw in Luton in U.K. Ihave been trying to get hold of one for myself. ive been in touch with the luton branch, only to find out the production line has been sent to India, (everythings disappearing from u.k.). I have a contact name and Number in India, ihave yet to get in touch, i,ll let you know what happens. Gerhards conversion is the way to go!
