Air Pack Bad??/Time for rebuild?
welldigger
17
Benton LA
So I assume the way a power bleeder works is you just pressurize the system and then bleed the air pack, then pressurize again and do each wheel? Correct?
Pretty much. I can pump mine up once and bleed the whole system. It doesn't take much pressure.
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
I use a small can to hold the fluid. One end gets clipped to a tire(for pressure) and we hook the other end to the master cyl. Easy as pie and fits in a small ammo can!
