Air pack pipe plug
Boatcarpenter
Marlborough, NH
Would a little heat around the pipe plug to help in removal without stripping it hurt anything inside the air pack or should I stick to strictly mechanical means? Thanks
ken
26
Houston Texas
Some of those rear caps are made of aluminum. I don't recomend heat. Untill it's the last resort.
cranetruck
92
Meadows of Dan, Virginia
That plug can be a PITA! When I first removed mine, I had the airpak all taken apart and actually had to drill it and got it out with a screw extractor. Judging by the paint primer, it had never before been opened (lubed).
Inside is an air chamber and there may or may not be oil or brake fluid present. Also, the cover plate with the plug is made of an aluminum alloy. Some heat may help, but go easy.
Just my 2 cents.
Good luck!
Stretch44875
Super Jr. Moderator
32
Tiro, Ohio
Amen to the PITA. Mine was tight! Hammered a smaller wench on and used a pipe. Good luck.
Dennis
Wyattearp
is that the small plug on the front side of the airpak? just curious as i removed a small plug while under my truck and brake fluid believe it or not, clear/clean started coming out. is that the plug in question..
Well its storming again could be a bit for im back online.
