Air pump leaking oil..
chuck500cc
DFW Area
It's leaking oil around the base. It's more of a seap than a leak, not enough to drip on the ground but noticeable. What could be the cause?
Westech
CPL
6,104
210
cow farts, Wisconsin
gasket maybe? there is a large base gasket. You can remove the air pump clean the gasket surfaces off really well and make a new paper one or use RTV for a new one. should not be a bad job at all.
Armada
Buick City, MI
:ditto:Bad base gasket. Replace it. One of the base bolts between the engine and compressor can be a bear to get at. You may have to do a little grinding on the wrench to get it on the nut.
FL_Frank
Apopka, FL
Gee, this sounds familiar. The entire left underside of my truck has a nice thin coat of engine oil from my air pumps base leaking (probably for years). Kept everything from rusting quite well, but need to address it eventually.
Good to know one can cut one out of paper board, and just RTV it - that'll make it a lot cheaper to fix. Thanks!:-D
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
been using cereal boxes for gaskets for years. I can't remember ever buying a thermostat gasket...heck for the longest time, I didn't even know you could buy them.
OPCOM
29
Dallas, Texas
My father used to very frequently make thermostat gaskets from gasket material sheet, and also used non-corrugated cardboard (like cereal box) for some places. He also would rebuild the starter and alternator, replacing brushes burnishing the commutator or slip rings, etc. Rochester carbs too, from the old Pontiac Catalina wagon. I know how to do these things because I learned from him.
Today's youngsters are mostly very spoiled today on all these ready made parts. OK some jobs are too big for certain people and sometimes the factory made part is more advisable, but here really should be a class taught in grade 11-12 on "self reliance and craftsmanship". I realize that is probably not included in the gummint objectives. The school I attended only offered home economics, which I took because it was full of chix.. So get that cereal box out, and trace the old gasket or the base of the comp.. and "just do it".
