Air shift install parts and t-case install.
Ditch Baby
Palm Bay FL
when you say "with driveshaft"
is this because the one with the sprag unit wont work with the air, or because yours was damaged/missing.
Picked up a air shift a few days ago... going to tackle this project in a few weeks... trying to get all my ducks in a row so i dont have any surprises.
coondog
Fall River/KS
Installed my air shift transfer last week, hooked up the air on Monday, but not the electrical and left the switch hanging in the air and thought I would try it out in the mud. Got STUCK, Transfer would just popped when engaged. Is that because electrical wire is not hooked up?
coondog
Fall River/KS
Are there adjustments I need to make, or just a bad air shift transfer? No real click when I switched on but dumps air when switched off.
gringeltaube
Staff Member
2,688
Montevideo/Uruguay
coondog
Fall River/KS
Good lord! I wish there were more room to check the air ram, without dropping the transfer. I installed it by myself, on a rock driveway. I'm sure it would have killed an ordinary man, the first time.
coondog
Fall River/KS
Not a bad fix after all. Took bolt out of hi-lo lever, dropped transfer with 3 pieces of allthread, took out 4 bolts on air cylinder removed nut on plunger and flipped it 180 degrees and reinstalled. (only engaged about 1/16" before, after the plunger flip, engaged 100%) Works like brand new, went though mud like never before.
Stretch44875
Super Jr. Moderator
32
Tiro, Ohio
Cookie!
Good job on fixing the airshift. It is possible to take the air cylinder apart on the truck, including removing the piston. But now you shouldn't have to worry about it.
Dennis
coondog
Fall River/KS
Now, all I need is 4-20" wheels to mount my 1600x20 XL's. I tried to rob 4 M35A3 wheels, but that was alot of wasted work. As the back spacing was to much. I need 4" back spacing on 10" wide wheels. Donations Accepted !
