June 6th, 2008.
Mine has a light on it,next to the air shift switch, with a light kinda like the high beam indicator light on the same bracket as the switch. You generally don't hear much of a clunk engaging, but the truck will fight you on very sharp turns ("Traction Steer, I Guess?) and you will notice an increase in her pulling power. This baby's almost as good as the transfer case on the Unimog, and a lot less pain to use when it's working right. HOWEVER.... If you do get stuck in a deuce (particularly one Wo/W), life will get worse before it get's better........ The pulling ability of these trucks when they have good footing is quite amazing (I know- I pulled a phone pole outta line about a 1-1/2' unsticking a farm tractor)............
Uncle Sam did pretty well when he designed the deuce.... I doubt if the FMTV's will be anywhere nearly as useful in their 30's and 40's...... about the only thing that would've improved it would have been seriously designed locking differentials.... like the Unimog's!!
Just my
worth.... (and who bothers to pick up
anymore?)
Sincerely,
Kyle F. McGrogan
1971 Kaiser jeep M35A2 Wo/W "Saddam's Nightmare" Desert Storm and Vietnam Veteran Deuce..686A Tan
1968 Johnson Mfg. Co. M105A2 1-1/2 T Cargo Trailer MERDC Woodland
1967 Hercules MEP023A Gasoline Generator Set, OD green
1963 Swiss Army Cargo Unimog, S404.114 MB NATO green
