Air shift question
m38inmaine
101
Maine USA
I see there is a kit called a air transfer lock kit, I assume this is the air shift for the front axel.
1. How do you tell if this kit will work on your truck?
2. Can you use lock out hubs with a non air shift transfer?
thanks
BFR
Rocket Surgeon
2,330
42
North Georgia
1. The only kits I've seen are meant to uprgrade/repair trucks that already have an airshift case.
2. while you can install lockouts on an nonairshift truck I doubt you wouldn't want to. the sprague would attempt to engage all the time.
Edited
houdel
11
Chase, MI
Re: RE: Air shift question
BFR said:
2. while you can install lockouts on an airshift truck I doubt you wouldn't want to. the sprague would attempt to engage all the time.
Joel - did you mean to say "2. while you can install lockouts on an NON airshift truck I doubt you would want to. The sprague would attempt to engage all the time."
BFR
Rocket Surgeon
2,330
42
North Georgia
DOh!
that is what I meant... :oops:
