Alcohol evaporator needed ?
wcolt45
parkersburg west virginia
Hello all, living in wv the winters arent as harsh as in other parts,but pretty cold none the less. I am wandering if a alcohol evap is a (necessity) to keep the old deuce goin in mild winter climates. Thanks
saddamsnightmare
80
Abilene, Texas
October 27th, 2011.
WColt45:
Being in West Virginia you will NEED a alcohol evaporator, not if. Don't jury rig it either. Yes the deuce does have hydraulic brakes, BUT the power to stop in any reasonable distance is determined by the air pack. Even with draining several times a day in Texas, when we got cold weather below freezing, all it takes is for the drain valve to freeze, and suddenly your truck is going to start to build ice in the air brake power assist system. My truck also has a Air-o-Matic steering unit, so I did not want it to freeze up.
The problem with where you are likely at in West Virginia, is that you are not going to get only one or two days of -32*F, you may get several weeks of it. And don't forget your air brake compressor is going to be breathing in all that spray from other vehicles, and it is going right to the air brake tanks. You could take the breather hose over to the air filter canister and cut some of the spray out, and if you fit the intake with a 90* elbow and put the mushroom on top, your gonna get less rain and spray on your air filter element, which will help the truck overall in the winter. It is money well spent in the long run when your trucks brakes work like they should, and not weaken out due to ice in the system.
Just my .02 worth, but from experience.
:driver:
bones1
Southern Maryland
Take a look here http://www.bendixvrc.com/itemDisplay.asp?documentID=5147
''air brakes come with a dryer installed and if it is working correctly, the system will never freeze. The idea is to catch and remove the humidity from the compressed air as it leaves the compressor, and not let it get into the system where it can freeze. Putting alcohol in the system is treating the symptom, but not the cause, and yes it may be bad for the seals''.
This dryer is very popular http://www.anythingtruck.com/commercial/airb_airdryer-ad9function.mv
cranetruck
74
Meadows of Dan, Virginia
Yes one line goes to the compressor and the other goes to the air tanks...my unit is plumbed in the main air supply line
Hmm...the military vaporizer is designed to let the compressor draw alcohol vapor along with the air to be compressed when running, it's not an "in-line" type of thing.
As far as the fluid, the military specifies methyl alcohol.
dittle
72
Albia, IA
I don't have an evaporator installed on my deuce and I've never had issues with it up here. I also have not seen an evaporator kit installed on the reserve unit vehicles up here either.
