JCole
- 0
- 0
- Vancouver, BC
Looks good. Good luck, you've got the fever..... its called "militrayvehicurlidas" LOL!!!!!![]()
That doesn't make sense. That sickness would mean you have an "inflamation of the military vehicle".
Yep; they shot that video at this location, on the day after the event. That's why the Warn stickers are all over the truck...If this has been covered already I apologize, but I saw this rig on a Warn add on tv
Kid has a soccer game...and then I'll be brewing beer for a few hourssewerzuk! what you doing saturday? mini rally up here if you want to come i want to drool over your truck and all your mods!
I have had a pineapple grenade shift knob in my hot rod for many years. I bought it at my local Army-Navy store, and the cost was around $8.I bought mine off of ebay and there was only one from that particular seller; for a few $$ more, there are a few other sellers with similar ones listed.
Amazon also carries them:
Amazon.com: Fox Dummy Grenade - Various Shapes: Sports & Outdoors
I've been running 10%; I never did get any higher than that. No hint of detonation at that level, and I have run probably 3000 miles with it. I kept meaning to go higher, but haven't had a chance (or motivation) to do it just yet.I was wondering how the methanol % experiments were going.
In a gas vehicle, the water meth mixture is used to suppress detonation and reduce EGT at higher boost levels. Gasoline is either drawn in (carburetor) or sprayed in (injection) before the compression stroke, so there is an air/fuel mixture ready to go off at any point during this stroke. Spraying methanol cools the intake air. Since methanol has a very high octane rating, it won't ignite until the spark plug lights it off. Too much heat in the cylinder, too lean of a mixture, too low octane, (and more factors) can cause detonation in a gas engine. Since methanol cools the intake charge, it reduces detonation.Why methanol over ethanol? And why not a 50/50 mix with water such as in winter window washer fluid? I would assume this you could run a rather high mixture as ethanol or methanol only has about 1/2 the stored energy of gasoline. Top alcohol drag engines run diesel-like compression ratios with lots of boost and don't detonate.
Don't take my word as gospel, I'm thinking out loud here. I figure the more you spray, the less likely you would be to detonate. **** turn up the fuel and Turbo.
A diesel will not detonate (even at extremely high boost levels) on diesel alone, because there is no fuel in the combustion chamber to ignite until the injectors spray it in (at the end of the compression stroke).
In a diesel vehicle (because of higher compression ratios), the methanol can actually cause detonation (because it auto-ignites before the diesel is sprayed into the combustion chamber). The risk of detonation is higher as you run an increased concentration. The deuce has a rather high compression ratio (even for a diesel), so it is more sensitive than most diesels to the mixture of methanol.
The reason that water/meth is used in a diesel is ONLY to reduce EGT's; its use allows you to turn up the fuel at the IP without causing EGT's to get too high.
My father and I were both fascinated by this. What type of rod have you found to work the best?Made this video about a month ago using the deuce as a stick welding power supply; I've used this method a lot out on the trail with good success. The deuce works well because it already has a 24v electrical system. I posted this in a separate thread, but since this is my build thread I thought I should post it here too
And, for all of the people who are going to say "Holy cow! That's SO dangerous!" or "your batteries are going to explode!" or "you're going to wreck your electrical system!", your concerns are duly noted. I've been welding with a pair of car batteries (as an emergency trail repair only, of course) for somewhere around 10 years; I have yet to destroy an alternator, battery, etc. because of this technique. No, its probably not "good" for the batteries, but my experience says that it won't destroy them as long as you don't let them become fully discharged.
[media]http://www.youtube.com/watch?v=b3vs7WCtRWE[/media]
Also, we were curious about the level of penetration into the metal?
I'm still around 10%; nothing special noted over time. At 10%, there's no real noticeable power increase (although I'm sure there is a few extra HP). But, it does keep the water from freezing here in NW oregon. It rarely gets any colder than about 20 degrees F, so I don't have the same weather issues you face!I was wondering what % methanol you run in your truck, and what effects you have seen over time. Is your water freezing?
Nice install! I am seriously jealous of that winch.
