- 4,006
- 3,408
- 113
- Peoria, Illinois
That darn truck looks SOOOOO factory!!! Amazing..... Thanks for sharing.
God bless,
Tony
God bless,
Tony
Try this link: http://www.chassisking.com/attachme...tainer-chassis-chassis-twistlocks-catalog.pdf
Well, I'm working on the fifth wheel module as we speak....I guess I will have to take some pics for you.....lol
Where did you get the truck lite LED's? I have been looking for a set.Today I'm happy to report, that I finally got all the hydraulic systems on the FEMTT side buttoned up!
I ran the last two missing hoses (1" hydraulic hoses SUCK, if you try to fish them trough a bunch of tight spaces by yourself....results in lots of "NAVY talk"!!!!) from the control console to the quick connect fitting bracket, under the left outrigger of the MHC.
These are the big ones that will run the DP drag winch on the front of the 'fifth wheel module'. They are controlled from the original M916 winch control valves and will still have the hi-lo speed selection available.
This concludes the modifications to the FEMTT's hydraulic system and the only other hydraulic hoses I have to install are on the module side. THANK GOD!!!!
I got my new Truck Lite LED headlights installed a couple of days ago and had a chance try them tonight.
All I can say is: They truly are amazing! I really like it that low-beam does not turn of when hi-beam is selected and I can see so much farther ahead then before!
With the FEMTT's top speed of 80 MPH+ and all the wildlife around here these will be a big improvement over stock.
Also, these are the second generation of Truck Lite's LED head lights and they are now uni-voltage. So no difference in part numbers and they work on any voltage from 10V to 30V!
Soni
I got them off of Ebay....NAPA is also selling them, but you have to put the military plugs on yourself.Where did you get the truck lite LED's? I have been looking for a set.
Sounds good thanks! NAPA said that they can get all the military Trucklite stuff, but it is all special order from the factory! Probably more expensive as well. They hade the civi ones in stock for around $450 a pair. Got the ones on Ebay for $237 for two!I'm getting ready to order some from NAPA with plugs on them. I'll find the part numbers and put em up.
Dave
The ones I'm talking about are second or third generation! I will look up the part number of the civi ones that I used tomorrow and get back with you. They are for the JK Jeeps and I know those are Omni-voltage for sure.Looked at them much closer and they are marked 12v only.
