M1009 NEWBEE 2013
- 0
- 0
- Colorado
Hi Everyone- Are there any good alternator 2 gurus out there? I need to run an issue by you..
alt 2 was not charging properly, so i bought a new iso ground unit from realelectric and installed it, install went good, no sparks after hook-up, so iso ground part of it was good. At start up, i get both Gen1 and Gen2 lights, no issue, truck starts and both lights go out, after its started.
Here is where the problem comes in, upon acceleration, gen 2 light does random dance of on and off, while running thru the shifts, while it is on and right before it goes off, it glows with a burst of brighter red, then fades and goes out. When truck is at idle, it does not come on, only while gaining speed and until it gets up to speed, then it goes out. As soon as you apply gas, in any manner, it comes on and seems to come on and off with shifts and when applying foot to gas pedal. While parked, if you press the peddle down quickly, it also comes on, then goes out as the engine settles down. I have proper voltages, both running and not running per the tm and the alt appears to be putting out proper voltage at idle. 14.77 V to rear batt at idle and 29.9V combined batts while at idle. I have taken it out twice today and put alt 1 in its place, without any issue, so it seems to be within the alt itself. any ideas on what to buy for alt parts that may be causing this? I even put the old alt back in and this problem went away. So it really appears to be this new alt that has the issue. i have checked and cleaned exciter plug, belt is tighter than tight and like I said, problem only happens with this particular alt. However, this is a new alt and Id like to fix the problem and allow it to operate properly. Can anyone provide what may be causing this or what else to check? I did read the TM and 15 or so stickies here but cant seem to be able to find it, also checked alt2 relay under dash (24v), on/off voltages (all check out) fusible links (all are good) but dont know much about alternators or what to replace or check.
Edit:Id like to add, while truck is at idle voltage gage is at the green line and stays there, it does not fluctuate while light is on or comes on and off. It stays at green line on meter. Just thought id add that.
Thanks Dave
Thanks Dave
