alt 2 question
howesblazer
billerica ma
I looked on the tm for the charging wiring and notice off of the second generator that thwe negative lead has some sort of ground with a "suppessor"? Mine only has a big red wire going to it......is that strange or does everyone elses only have one wire on the negative post of the second alt?
1,172
You do not need the suppressor.
Warthog
229
OKC, OK
It is used for Military radios. No radio then no suppressor needed.
idM1028
Somewhere in Nebraska
The red wire off GEN 2 should have at least 24 volts (when running around 28.8 is better) The red wire with the white tracer should have at least 12 volts (again, 14.4 when running is better)
