Lild
- 2
- 8
- Nashville,nc
1986 m1009
did the roscommon 12v conversion back in the summer. I did the one where u remove the drivers side alt.
Drove home today, & notice the the wipers barely want to move, lights seem dim. When i got home, turn truck off, & tried to restart, no go. Had to go some where for a while. So a few hrs had pass, jump started the truck, fired right up. Got out my digital volt meter, checked batters, & alt, each read 12.v running. Figured the alt was going bad. So i changed out that one with the drivers side one i took out back in the summer, jumped again, batteries read 12.2 & alt read 12.2, took it for a quick drive to charge things up, notice lights got dim. Got home, 5 mins later, rechecked, 9.8 for every thing.
So i assume that both alts are bad, i may take the other to have tested, & my question is,
1- is there any thing that would keep the alt from charging, & why would it go from 12.2v to 9.8
2-will a reg civi alt work in place of the current alt. the batteries are wired in parallel, so is the isolated ground thing an issue, & i noticed that the replacement alts had no mounting point on them for the ground wire (like i have on the current rosco setup to the block.)
3-what amps is required, i see 78 & 108 amps. Most threads i see say 100 but again not sure since i converted to 12v system.
Thank you for any help
