- 2,479
- 27
- 38
- Houston Texas
As some of you may know i have been cutting diesel with used motor oil to cut down on fuel costs. Desert Rat and i won a couple of centrafuges on a auction. Today they arrived and i put them to work even before i unloaded them from my truck. These gems are also refegerated, down to -20deg c!!!! The first batch i tried was used castrol 20w-50. I had already strained the oil through coffie filters 3 times. After running about 1 gallon at 2500 rpm's for 5 minutes some small bits of carbon settled to the bottom of the jars. So i tried running it again for 10 minutes with the fridge switch on. When i opened the lid i found small ice crystals in the bottom of the jar. Talk about water seperation!!!! So my next batch was 90w gear oil. (thanks D RAT T-case) After 10 minutes the oil seperated metals, some trash and i noticed the oil on top was thinner. As i moved the jar the oil reblended. The gear oil also became lighter in color. Although the motor oil did not. I have almost 5 gallons done. I'm going to try higher than 20% oil in the fuel in small incerments. Next step Duece fuel tank.
