Alternative to D51R Optima on MEP-802A
rcamacho
838
Bainbridge Island Wa
I have one bad 51 that may not be recoverable on the AGM charger. This one is ridiculously over priced. Any alternative more reasonably price?
NDT
6,502
Camp Wood/LC, TX
There is a group 51 agm available but be aware it has little tiny posts for a disgusting prius. I bought one at NAPA, didn’t really look at it until I had it in the store parking lot, ah no. Back it went.
Ray70
5,869
West greenwich/RI
I also use regular 51R batteries, usually Napa Legend's but I have several customers who have experimented with the small 280-300 CCA ish' garden tractor batteries with decent success ( if anyone is on a tight budget )
You can get them as cheap as $39 sometimes.
They have the flat terminals with a bolt hole through them, but they remove the battery cable bolt, slip the terminal on the battery between the 2 flats on the battery cable and reinsert the bolt through the cable and battery post and viola! Cheap battery installed!
However, I have my doubts these will last anywhere near as long as a good AGM, but for anyone in a financial bind it is a cheap option that can buy you a couple years....
Coug
4,351
Olympia/WA
as a short term warm weather battery they will probably do okay. They definitely won't last as long as a quality AGM battery, but as you said, it's a budget option, and I'd only use them if nothing better was available.
In cold weather the output of the battery goes down and the cranking difficulty goes up, so having something bigger is definitely better.
For comparison, I recall RWH over in the HMMWV forum saying he's even seen the lawnmower batteries being used in a HMMWV that came into his shop for work.
