alternator adjust
shootiniron
13
Escalante,Utah
When adjusting the output of the alternator do you turn the screw head under the allen plug CLOCKWISE or COUNTER CLOCKWISE to increase the output ? Also is it a slot head or philips head ?
doghead
4 Star General /Moderator
1,185
NY
I use my digital volt meter to set my voltage adjustment. I don't trust the dash gauge to be accurate. I have some trucks that I set with my DVM at 28.5v and the gauges are not reading on the "tic" mark. I rechecked the voltage at the dash gauge and it's 28.5 there also. I read my gauges as a reference only, nothing too precise about them!
Gastrap
183
Central Iowa
Yes, clockwise to increase.
Mine was putting out 31.5 when the dash gauge was on the mark,now at 28.5 its right on the line between yellow & green.
Davidwyby
236
CA
My pot is backwards...I turned it counterclockwise or out initially and got 30+v.
Tow4
669
Orlando, FL
+2 the one on my M929 is counter clockwise to increase voltage also. I think its the same alternator.
