Alternator Bolts
salt6
B'ville, OK
What size are the bolts for mounting the alternators to the alternator brackets? My truck was a parts queen and was missing both.
OL AG '89
9
Kingwood, Texas
the bolts are a size that are not available at the local hardware store... My previous experience... I ended up paying about $12 each for the longest one on the passenger side alt.
I would head to the local junkyard and see what you can find.... or put a WTB on the classifieds.....
Oh and check the -20P it will tell you everything you ever need to know!!
OL AG '89
9
Kingwood, Texas
SECTION II TM 9-2320-289-20P​
FIGURE 29. ALTERNATOR AND MOUNTING HARDWARE, RIGHT SIDE (ALL EXCEPT M1010).
SECTION II TM9-2320-289-20P
(1) (2) (3) (4) (5) (6)
ITEM SMR PART
NO CODE CAGEC NUMBER DESCRIPTION AND USABLE ON CODES (UOC) QTY
GROUP 0601 GENERATOR, ALTERNATOR
FIG. 29 ALTERNATOR AND MOUNTING
M1010)
1 PAOZZ 11862 14005953 SHIELD,EXPANSION 1
UOC:194,208,209,230,231,252,254,256
2 PAOZZ 11862 14067724 BRACKET,ENGINE ACCE 1
3 PAOZZ 11862 1635490 BOLT, SELF-LOCKING 2
4 PAOZZ 20796 42-6923 BELT,V 1
5 PAOZZ 11862 14067717 BOLT,MACHINE 1
6 PAOZZ 11862 11506101 NUT 2
7 PAOZZ 96906 MS27183-16 WASHER,FLAT 2
8 PAOZZ 11862 14067714 BRACKET,ENGINE ACCE 1
9 PAOZZ 11862 14067725 SPACER,SLEEVE 1
END OF FIGURE​
29-1
#5 as listed is a 3/8" x 6.375...... or something close take the part number to local GM dealer or google part number 14067717 as see what you get......
the rest of the bolts are common items....... again you should be able to get lengths from GM or Googling...
found thread on here Catastrophic failure of passenger side alternator mounting assy
mentions that you can order from GM....
and it's expensive lik the thread says about $16 for one...
Good Luck
