3rdmdqm
- 145
- 43
- Woodbine Maryland
I'm pretty sure the alternator on my deuce crashed. I noticed the volt guage reading at the yellow/green line, then when starting the truck the guage went all the way left. Now its in the yellow. Put a meter on the batteries, they are 24 volt. When turn the power to the guages on, voltage dropped to 23.8 while running. So we put the meter on the alternator itself. Get 24 volts when not running and 24 volts running, so I know it is getting power from battery. Then when running and turn on power to guages and/or lights, voltage drops to 23.8 again at alternator. Shouldn't alternator be cranking out about 27 volts at least? Revving engine does nothing to output. Also, tried turning the hex adjustment screw for the alternator, nothing, no change. Am I missing something here or is my alternator dead? Should I try getting original alternator rebuilt? Its on a 1984 White LDT engine, but deuce itself is a 68. Avengeusa looks like he has a nice replacement alternator for a reasonable price, probably cheaper than trying to rebuild mine. Suggestions?
