Alternator question
mattrains
Flowery Branch, GA
I picked up my hummer today and put a used alternator in it because the alternator that was in it was torn up.
When I installed the new one it worked fine and was charging the batteries and also had a good output from the back of the alternator. Now, 7 hours later its.not charging. Any ideas or does anyone have a wiring diagram for the alternator or know what each wire goes to?
Thanks in advance, I'm new to the 24 volt stuff.
mattrains
Flowery Branch, GA
Turns out it was the adjustment screw on the top of the alternator was turned down to 20 volts. We pulled into a truck stop, adjusted the screw up to exactly 28 volts and everything has been running just fine. Thanks!
