timarr
- 1
- 18
- PT PLEASANT N.J./ MARTINSVILLE V.A.
I spent some time today to test my 5 spare alternators . Went to advance to use their test bench. The code you need is p7157 which is the code for a 80s 100amp si27 alternator. use electrical connector c. hook up 2 wire c connector in its spot, positive to positive post and ground wire not to case but negative post. then run test. after test you can view its results . I had good results on all 5 ,good luck with yours!
