Alternator testing at advance auto
I spent some time today to test my 5 spare alternators . Went to advance to use their test bench. The code you need is p7157 which is the code for a 80s 100amp si27 alternator. use electrical connector c. hook up 2 wire c connector in its spot, positive to positive post and ground wire not to case but negative post. then run test. after test you can view its results . I had good results on all 5 ,good luck with yours!
sneekyeye
142
ALABAMA
Yeah, set a multimeter on resistance, and put it in the ground terminal and the other lead on the case. It should read infinite if it's still properly isolated.
