aceventura2225
- 0
- 0
- Hartland, Michigan
I have a m1008. I was wondering how to test the alternators. The Passenger side more. What terminals do you put the volt meter on and how much voltage should be coming out of it. I had the voltmeter hooked up and it was reading 20 something volts. i was confused because that doesnt tell me if it was charging. i know when i hook it up to the driver side alternator i get 14 volts which i know is charging. Im unsure about the passenger side though. ive been having battery problems. i recently had my passenger side alternator rebuilt and when i hooked it up it smoked out real bad and i need to check if it is ruined. If i have it rebuild what should i tell the rebuilder? is it a 24 volt alternator? i dont know why it smoked so bad. therefore, how do i check the alternators for charging?
