Csm Davis
- 393
- 83
- Hattiesburg, Mississippi
Why would alternator Wire 566 be unhooked and taped up? I have seen this on several trucks and now i am having an electrical issue and found it has been done on my wrecker.
From what I have researched, #566 prevents the starter from being engage while the engine is running. It seems this wire delivers whatever signal (voltage, freq.) to the protective control box (mysterious black box by the drivers side firewall) for this.
9 CIRCUIT 566 - Controls a relay in protective control box that prevents starter from reactivating</SPAN>
while engine is running.
New alternator in and charging but still having problems will try another black box tomorrow.
Not sure Andy my gage was not reading and I didn't have my meter to test with just had to shotgun it by changing parts till it worked.did you have a problem with under or over charging ?
