AM-1780A schematic needed or help with resistor R73
4,612
Trying to repair the AM-1780A I have. I've found resistor R73 is burnt. I've not found the schematics for the A model yet. Also googling the resistor numbers I can make out haven't found a value to replace it with. Does anyone have a TM for the AM-1780a with the schematic or could share what the resistor value is for this?
4,612
I haven't found anything on public release for the "A" model. But I did see mention of:
TM 11-5820-898-20P. So maybe if there's the -10, 20, -34, exc. it would all share TM 11-5820-898 as the prefix I think.
4,612
Well I pulled the resistor out, looks like it was a 10ohm resistor. Replaced the resistor and tried again. No love. There was one other resistor that looked like it got hot. But wasn't to the point this one was. I might try pulling that one out of the board and replace it. I did notice at least now when I key the intercom I see some current draw on my bench power supply. So some of it is working. But without a schematic, pretty much going to be a lost cause I think.
Guyfang
22,095
Burgkunstadt, Germany
Sorry. No joy. But my buddy said maybe someone he knows, may have worked on them and would have an idea what could be the problem. He will ask.
SCSG-G4
PSVB 3003
3,193
Lexington, South Carolina
A long time ago, I had a stereo system that blew a resistor on one side, so I was able to look at the corresponding schematic for the other side and figure out what the value had been. When I replaced the resistor, I used four times the wattage, but the same Ohm value. Never had any more problems!
4,612
There was one more discolored resistor in there. I'll pull it apart again and pull that one out to see if I have a suitable replacement. I think it was also a wirewound 2w resistor though. I also didn't think to patch audio into the input to see if it would do anything. Guess I'll at least try that before I declare it a lost cause.
