AM General M917, 916 etc… pusher axles
Camoguy
66
Oxford nc
Does anyone have one of these? Could you get me the info off the pusher axle? I have a 4 x 4 truck that I would like to add a pusher axle and I can’t find one to spec out because of the transfer case. I think if I could get one of these off a parts truck or I can find out who made them I can probably have one made.
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Does anyone have one of these? Could you get me the info off the push your axle? I have a 4 x 4 truck that I would like to add a pusher axle and I can’t find one to spec out because of the transfer case. I think if I could get one of these off a parts truck or I can find out who made them I can probably have one made.
Its a Rockwell TNKD967-P. 20k capacity
It's 46in front to rear. 34in inside frame. Weighs around 15 to 1800lbs
Camoguy
66
Oxford nc
Wow thats heavy! Is the axle tube bolted on with u bolts or welded? I cant tell because of the airbags in the way. How deep is the horseshoe?
simp5782
9,509
Mason, TN
The Horseshoe section is the axle. The tubes are welded to the horseshoe then out to the spindles.
The horseshoe is a 18 to 20in deep at lift. I don't know what it is with the bags dropped.
