- 3,724
- 782
- 113
- Michigan
Replaced Front springer seats, Installed HEMTT buckets on a custom base.
I found myself up with the birds today and decided to install the Cab reinforcement plate and the long put off bucket seat project.
I don't know if this has ever been done before but I came up with an excellent base to mount these HEMTT bucket seats. I picked up 2 sets from Ritch a SS member right here in Michigan. The first set I am installing in a 1028 I have not completed yet.
The second set I am installing right now with 50 Cal ammo cans as a base. Last year I picked up a chit load of 50 Cal cans from doghead in Ga. I was on my way to the shop to sheer up and weld a box base then I had a thought about using the ammo cans. They are plenty strong. I used 2 cans per base. The height is perfect and they fit the seat base with no hang over. I welded and bolted the seat base to the lid. I also drilled 5 1/2" holes per can. 4 corners and the center. I used #8 nuts and bolts with over sized washers. I then welded 12-1" beads for the can base to the floor of the cab.
I waited for the welds to cool then cleaned up the slag and debris. Took a tube of Owens Corning 100% black silicone and formed a base gasket and covered the fresh welds. After I was complete with the passenger side I was impressed, I even have a secure/water tight storage place hidden under the seat. I am liking this mod.
