islandguydon
- 787
- 113
- Michigan
I had twa@ezdn.net
Build me a few Ammo Can Grills, Today I received the grills and decided to check out how well they worked. Pictured is the grill painted with hi heat flat black. Next is the parts Tim used to make the grill, He built a stainless steel bottom riser to keep the charcoal 2" off the bottom and above the rear air intake vent which he built a door baffle. Next I placed 9 charcoal brickets in the bottom, Took 10 mins to get hot. Then I placed the Stainless Steel grill cover the 5 Stainless Steel holding pins. There was a nice even heat across the grill. The steak took 4 minutes each side for medium well and I am impressed. Contact Tim and I am sure he can do the same for you.
Just thought I would share my experience with Tim's custom BBQ grill.
