AMMPS through gov auctions
peapvp
1,156
Basehor, KS
Folks,
similar to what we have seen with o hundred and 8 hundred series, 372 AMMPS (1030 to 1070) have been sold through gov auctions since August of last year.
The average price tag was US$ 6,500 with many as high as close to 12K and the lowest non running was at $ 3,750
Amazing what stimulus money and child tax credit can accomplish
Congratulations, I would like to wish every proud new owner the best of luck
and don't forget the diapers.........
Please feel free to contact me if you have any questions about your new AMMPS and you don't feel comfortable posting here publicly.
Peter
P.S. the US Military uses a paper to clean the oil dipstick which is commonly referred to as Diaper because of it looks and feel.....
rickf
1,518
Pemberton, N.J.
Can you even work on these without a diagnostic computer? For that kind of money I will buy a commercial unit that parts are readily available for. I can have a natural gas unit set up for less than 8 grand! Power goes out and genny starts up, I don't even have to go outside.
peapvp
1,156
Basehor, KS
Yes, a regular DMM or VOM will get you pretty far. Some members here have successfully changed the LCD's in the CDS and I have revived one which had cold solder connections and corrosion inside the CDS.
Otherwise troubleshooting is straight forward by using repair manual and the error / fault codes on display
I have not had a CDS here with defective semi conductors. Some off those are fairly easy to change other require special solder and x-ray equipment for proper pin alignment.
Nothing really out of the extraordinary compared to other today's electronics.
Peter
rickf
1,518
Pemberton, N.J.
If you are talking fault codes then you are working with an ECM. And ECM's are basically computers so diagnostics will go beyond multimeters on a lot of stuff. And I was thinking more along the lines of the engines and engine controls since I am a mechanic and not much of an electronics technician. Are the engines also controlled by ECM?
peapvp
1,156
Basehor, KS
The ECM in the AMMPS are integrated into the
DCS, which stands for Digital Control System
it also has the AVR and governor control in it
ECM, AVR, Governor Control and I/O’s are on back circuit board
front pcbs:
Left:
Communication
U- shape: I/O, voltage regulator, lcd backlight etc
Top rotary switch: E-Stop
Lower rotary switch: ECS Engine Control Switch
Rectangular board: CPU, RAM, ROM, SSD, Video etc
peapvp
1,156
Basehor, KS
the error codes are displayed on the LCD
the CDS has USB connector and you can access all stored error codes with a pc/laptop which has inpower AMMPS installed.
cummins has two versions available, military and civilian. They cannot be interchanged.
further, the military uses special IBM laptops for many applications and some software may not run on regular ibm compatible PC’s
in the full version of the military inpower AMMPS, all parameters can be accessed and altered. Like upper and lower limits for voltages, currents, rpm’s, pre heat time etc etc etc.
The firmware can also be updated from laptop
the only thing you cannot do is remote start through usb or serial port. This option is only available on commercial AMMPS.
But you can buy our auto start kit for Military AMMPS and retrofit it (see link in signature)
