An easier way to turbo an M800 truck
JasonS
201
Eastern SD
Finished up the driver's side hood panel. I cut out a square comprising the factory hole where the intake passed through and will use it on the passenger side.
I used the hinges and latches from a spare deuce side cover to make this cover open. Not perfect but nothing on the truck is.
JasonS
201
Eastern SD
Plasma cutter is a little coarse for this. I start the cut with an abrasive cutoff wheel and finish with a reciprocating body saw. Nice cut and doesn't put all the cutoff dust in the air.
