Onetrackmind
- 0
- 1
- Allen, Tx
Hey all...brand new M998 owner and I also have starting issues. I’m hoping for some guidance. I have also downloaded the TMs and searched quite a bit on SS for answers...still scratching my head though.
First start of the morning takes a while, but subsequent starts are a breeze (it’s hot in TX). Symptoms:
No Wait light at all...ever
No battery draw when switched to run and definitely no cycling
Takes a lot of cranking in the morning
Lots of white smoke while cranking
All 8 GPs failed an ohm test in the head
One GP has a severely bent connector
The three GPs that I tried to remove were swollen
Here is what I have done. Disconnected the Neg on batteries and then cleaned and lubed the cannon plugs on the KDS (it has a KDS S3 w a yellow band TSU). Cleaned and lubed the plug on the TSU. Found all of the grounds and cleaned/lubed them too. I plan on building a supplemental grounding harness in the next few days and have already ordered new GPs and a removal tool. I also took the Interstate batteries that are in it out and had them tested at the parts store. They tested out great, but now that I think about it...they didn’t load test them.
My question is this. It seems like I should probably replace the KDS and TSU as well...probably fried. Which S3 start box should I get? Are the Nartron and KDS equivalents? Or is one better than the other? Also, can the KDS be analyzed by testing equipment for civilian cars?
Thanks in advance!
Thanks in advance!
![](http://uploads.tapatalk-cdn.com/20180605/caec3f5078e931a859e26a5a939accb3.jpg)
