Another 6.2 issue bad freeze plug
ranchhopper
139
south elgin illinois
I have another issue with the 1009 its leaking a lot of coolant from the back of the engine inside the trans bell housing. I assume the only thing it could possibly be is a rusted freeze plug. I was wondering if anyone had replaced the rear freeze plug while the engine was still in the truck. I realize the trans has to come out but is there enough clearance to pull the old one and install the new one being so high in the block.
ranchhopper
139
I was going to probably do that I just have little time for that now I just bought a 1008 last week I have to hire a transport to go get it I'm sure its going to have issues too. If it has a good running engine I may swap it into the blazer and freshen up the blazer engine and drop it into the 1008 in the spring. The 1008 was said to have a bad trans maybe I could get lucky for once and it would be a vacuum issue and that's it.
LT67
513
Bowdon, GA
I have the same issue at the moment, freeze plug next to the drivers side motor mount is leaking.
cucvrus
10,505
Jonestown Pennsylvania
You could pull the old one out and replace it with a block heater. Or pull the steel ones out and replace them with brass or expandable rubber plugs to make it easy. Good Luck. I had a tool for installing them. I lent it out and the man died. I never went back looking for it.
