- 409
- 11
- 18
- Dittmer, Mo.
Stumps, Thank you for that write up. My blower is working good, but the day will come. I'll at least try to fix mine now. Amasing what some of you know about these trucks. Ron
Hi BC,OK Stumps,
Here is a question for you. I mounted my heater in the cab and the blower motor is positioned so the blower shaft
is operating in a vertical position. Had some trouble so pulled the motor and fired it up in the vertical positiion. It works
but jumps up and down. When I operate it in the horizontal position, it runs fine. I suspect the end bearings are not
made for vertical operation. Having taken one apart, can you confirm this?
Thanks,
BC
They have no cooling, so it isn't too surprising that they would run rather cozy. However, most are not burning up. The more common problem is for the internal ground wire for the field coil to lose contact with ground. Fix the ground problem inside of the motor by adding another nut (as I described earlier in the thread) and you are good to go for a long, long time.With all these smoked motors, i need a different squirrel cage fan for mine. mine vibrates like crazy. must have gotten bent at one time. The motor itself feels really hot when it is running. i wonder if mine is on its way out.![]()
